Hi all,
I thought it may he good to have a feed where we could share any tips and tricks to do with any of the Grid Connect Range being Arlec, Deta, Verve, Orion.
I am learning from trial and error and really just accident so sharing with others and sharing back we may be able to create some good learning information for us all.
Please post below starting with what the trick is as the title then how to do so as the body of information.
Carl
Hi @KayEm
You could try another app called Smart Life instead of Grid Connect.
It's the parent app of these devices.
Otherwise it sounds like the devices still have their data on them and are not allowing to flash to them
When trying AP mode (slow) you are selecting the Arlecxxxxx or Smartxxxx wifi when it asks you to?
I'm sure you are just checking.
And you are on 2 4ghz bandwidth wifi only as well to pair them?
Those steps are usually the ones that are moselt important.
Cheers Carl
Hi @kh17,
I've spoken with the technical team at Arlec (Deta's parent company) who have told me that music mode will only work with music that has been downloaded to your phone, not streamed music through apps like Spotify or Apple Music.
You can download music through these apps so they can be accessed without an internet connection. Try doing this and see what results you get.
If this is not successful, it is likely worth giving their technical team a call on 1300 267 168 in Australia and 0800 003 329 in New Zealand so they can talk you through the troubleshooting process as you do it.
Let me know if you have any further questions or require further assistance.
For anyone that is unaware there is another app called Smart Life that is built on Tuya devices which is the same technology of Grid Connect.
This week they rolled out a fairly big update on the phone app for both Android and IOS
Here is the main new features
1. DIY Homepage Customization
The new dashboard allows for full customization of your app's homepage, ensuring it matches your preferences and smart home setup.
Drag and drop widgets to create your ideal layout.
Highlight your most-used devices for instant control.
Personalize your dashboard to suit your lifestyle.
Your smart home is unique, and the app can now reflect that individuality!
2. Effortless Control for Homes with Multiple Devices
Managing numerous devices is now simplified with The Smart Life App Dashboard, featuring:
Rich control widgets for easy device management.
Streamlined navigation to find and control specific devices more easily.
Enhanced user experience, tailored to large smart home ecosystems.
Whether you have a few devices or a large ecosystem, this update saves time and effort.
3. Android Auto Integration
Enjoy a seamless smart living experience with Android Auto support:
Control your smart devices directly from your car dashboard.
Perfect for managing your home while commuting or on the road.
Provides ultimate convenience with seamless integrations
Hi all, I have a property which I run wifi extenders around to gain wifi coverage. Why is it that I can’t connect to various devices using my primary router address. I have to connect to the extender in order to gain access to the Gridconnect device. Thanks
Welcome to the Bunnings Workshop community @Tinmann. It's marvellous to have you join us, and many thanks for your question about Grid-connect devices.
That would likely be a question best run by the Grid-connect technical team, who can be contacted through their Contact Us page. They can check your setup and technical specifications. However, let me tag one of our smart home experts, @CSParnell, to see if he has any thoughts.
Hi @Tinmann , @MitchellMc
I would dare say your primary router is set to 5GHz or 5 + 2.4GHz where by your extenders are probably 2.4GHz.
If your primary is 5+2.4 disable the 5, try to connect your device/s and if successful then re-enable the 5ghz again. If not successful with 5 still disabled try to connect with AP mode (slow flash) mode rather than EZ (fast flash) mode and see if that works.
Don't forget to re enable 5GHz again
That is the 2 main reasons
Let me know how U go
Thanks so much. Great to be part of community that helps each other
Cheers. I’ll try that and let you know how it goes
Hi Tinmann,
I am afraid it is a little more complicated than has been suggested. For a start. the IP address of the range extenders will have to be in the same subnet as your main network ie main router. For arguments sake, say the IP address of your router is 192.168.0.1 Then you need to assign fixed IP addresses to the range extenders that are in the same range ie 192.168.0.XXX Devices that are NOT on the same subnet cannot communicate.
Unfortunately, range extenders use non conventional networking methods. For example, the MAC address of the range extenders is often altered by their software. Normally MAC addresses are fixed on a piece of hardware. That is not the case with range extenders. This means that you may see a range extender listed twice in the routers list of connected devices. All very confusing. Just ignore any device which does not have the IP address that you gave it.
There is a lot of info about range extenders and their weirdness on the net.
However if you make sure all your devices are on the same subnet (ie the IP addresses of all devices start with the same three numbers but have a unique number in the fourth position they should be able to talk to each other.
There is a lot of confusion around the 2.4 GHz and 5 GHz networks on modern routers. Just because the devices are connected to a different radio in the router does NOT mean they cannot communicate. The two radios are linked inside the router and they will have the same IP address structure.
Some people claim to have issues when pairing new Grid Connect devices (which ONLY connect to a 2.4GHz radio) when the 5GHz radio is running.
I have never found that to be the case and I have paired literally dozens of Grid Connect devices.
People also confuse 2.4 GHz and 5GHz in routers with the 4G and 5 G mobile phone networks. They are completely unrelated.
I hope this helps. Computer networking is a complex subject but if you bother to learn the basics you should be able to make any home network perform properly.
Good luck!
I will try to help more if necessary but you really need to have a basic networking knowledge to confidently set up a network.
Ian
