Grid Connect tips, tricks and help
CSParnell
Hi all,
I thought it may he good to have a feed where we could share any tips and tricks to do with any of the Grid Connect Range being Arlec, Deta, Verve, Orion.
I am learning from trial and error and really just accident so sharing with others and sharing back we may be able to create some good learning information for us all.
Please post below starting with what the trick is as the title then how to do so as the body of information.
Carl
CSParnell
Re: Grid Connect Light Globe won't enter Pairing Mode
Hi @KayEm
You could try another app called Smart Life instead of Grid Connect.
It's the parent app of these devices.
Otherwise it sounds like the devices still have their data on them and are not allowing to flash to them
When trying AP mode (slow) you are selecting the Arlecxxxxx or Smartxxxx wifi when it asks you to?
I'm sure you are just checking.
And you are on 2 4ghz bandwidth wifi only as well to pair them?
Those steps are usually the ones that are moselt important.
Cheers Carl
Re: Grid Connect lights music sync
Hi @kh17,
I've spoken with the technical team at Arlec (Deta's parent company) who have told me that music mode will only work with music that has been downloaded to your phone, not streamed music through apps like Spotify or Apple Music.
You can download music through these apps so they can be accessed without an internet connection. Try doing this and see what results you get.
If this is not successful, it is likely worth giving their technical team a call on 1300 267 168 in Australia and 0800 003 329 in New Zealand so they can talk you through the troubleshooting process as you do it.
Let me know if you have any further questions or require further assistance.
CSParnell
Re: Grid Connect tips, tricks and help
Smart Life App New Features
For anyone that is unaware there is another app called Smart Life that is built on Tuya devices which is the same technology of Grid Connect.
This week they rolled out a fairly big update on the phone app for both Android and IOS
Here is the main new features
1. DIY Homepage Customization
The new dashboard allows for full customization of your app's homepage, ensuring it matches your preferences and smart home setup.
Drag and drop widgets to create your ideal layout.
Highlight your most-used devices for instant control.
Personalize your dashboard to suit your lifestyle.
Your smart home is unique, and the app can now reflect that individuality!
2. Effortless Control for Homes with Multiple Devices
Managing numerous devices is now simplified with The Smart Life App Dashboard, featuring:
Rich control widgets for easy device management.
Streamlined navigation to find and control specific devices more easily.
Enhanced user experience, tailored to large smart home ecosystems.
Whether you have a few devices or a large ecosystem, this update saves time and effort.
3. Android Auto Integration
Enjoy a seamless smart living experience with Android Auto support:
Control your smart devices directly from your car dashboard.
Perfect for managing your home while commuting or on the road.
Provides ultimate convenience with seamless integrations
annazub
How to connect Orion gridconnect security cameras to 5G internet?
I recently upgraded my internet to a 5G and discovered that the cameras are only supported by 2..4 and therefore went through the guest network to create a 2.4 connection. I went through the steps of pairing and connecting my cameras and am having no luck. I went through the troubleshooting list and still no luck. Any suggestions would be appreciated.
Re: orion gridconnect security cameras
Hey @annazub,
great question and welcome to the community.
I'm assuming you got a new router as part of the upgrade, and as you point out it has a guest network capability that allows 2.4 Ghz devices to connect.
Specifically Telstra smart modems do this, but I know for a fact that other brand router/modems have similar features:
If you have enabled the 2.4 Ghz network, make sure that you don't have "network band steering" enabled.  I had to turn that off.
On my router, this allows devices to try to connect to the fastest of the network SSIDs, and I've found that doesn't work.
Also, on whatever device you are using to pair the grid connect device, after you have done the above, have your device FORGET the network, then connect, and ONLY connect to the 2,4 Ghz SSID, then try to re-pair the security camera.
There's a full troubleshooting guide here: grid connect wifi troubleshooting   Option "B`' worked for me, and I've done this for people on Optus modems (slightly different, but ends up in the same place).
Let us know if this helps, or give me the make of your Router and I can see if it's that.
Hi @annazub,
A warm welcome to the Bunnings Workshop community.
I trust @Walter's advice has helped, but if you still have any questions or issues, please let us know so we can assist further.
Let me know how you went.
All good thankyou. Family member resolved the issue. Thanks again.
Thanks for the update, @annazub.
Tinmann
how to connect grid connect around a property
Hi all, I have a property which I run wifi extenders around to gain wifi coverage. Why is it that I can’t connect to various devices using my primary router address. I have to connect to the extender in order to gain access to the Gridconnect device. Thanks
Re: how to connect grid connect around a property
Welcome to the Bunnings Workshop community @Tinmann. It's marvellous to have you join us, and many thanks for your question about Grid-connect devices.
That would likely be a question best run by the Grid-connect technical team, who can be contacted through their Contact Us page. They can check your setup and technical specifications. However, let me tag one of our smart home experts, @CSParnell, to see if he has any thoughts.
