123 Blocks
deano1966
Building a Reputation
123 Blocks
Do you use a 123 Block in your shop? This tool is very useful for ensuring the blade or fence on your mitre saw or bandsaw is exactly 90°.
The 123 Block has standard dimensions of 1 x 2 x 3 inches. This version also has threaded holes to join multiple blocks together to create jigs and so the block can be attached to machinery.
Noyade
Re: 123 Blocks
Morning @deano1966
No, I've never seen those before, so I had to Google...
Noyade
Re: 123 Blocks
But I kept getting distracted by the number of planers that guy has?!
Noyade
Re: 123 Blocks
My woodwork is rather rudimentary - not a lot of precision.
I just use a small square for my table saw, drop saw and band saw.
Re: 123 Blocks
Hello @deano1966
Thank you very much for sharing your knowledge about this tool. I saw it being put up against the fence and a sawblade showing if it was straight. I use a similar tool as @Noyade, the Craftright 300mm Combination Square
MikeTNZ
Re: 123 Blocks
Hi @deano1966,
Yes, I've owned 6 1-2-3 blocks for the last 20 years after having been shown them by an engineer.
I made my own ones out of steel, they were a nightmare to fabricate, but you only have to do it once.
I can't even begin to explain how helpful they've been over the years.
Good call on letting everyone here know about their presence!
Mike T.
