Grid Connect tips, tricks and help
Hi all,
I thought it may he good to have a feed where we could share any tips and tricks to do with any of the Grid Connect Range being Arlec, Deta, Verve, Orion.
I am learning from trial and error and really just accident so sharing with others and sharing back we may be able to create some good learning information for us all.
Please post below starting with what the trick is as the title then how to do so as the body of information.
Carl
- Labels:
Lighting and Electrical
Re: Grid Connect Light Globe won't enter Pairing Mode
Thanks Mitchell!
I'm so happy I've joined, there is so much information here. I think I'll be very busy looking at everyone's projects.
I've emailed the grid connect support team so hopefully they can help.
2 of the globes were purchased in September this year so at least they are still under warranty!
Karen
Re: Grid Connect lights music sync
Hello @kh17
There was a related discussion regarding the music sync feature of Deta down lights - Grid connect - why is the music sync feature missing? by @Bob_a. Can you please tell me the exact model number of your downlights and I can ask Deta if the model you have has a way to run the music sync function. As soon as you give me that information, I can look further into the matter.
The model is DET902P4HA.
I thought I had seen somewhere in the box/instructions that the feature was included but going back to look maybe it’s not. I just assumed that as the app detects the specific lights that it would only show me options to select features that are actually available?
Hi @KayEm
You could try another app called Smart Life instead of Grid Connect.
It's the parent app of these devices.
Otherwise it sounds like the devices still have their data on them and are not allowing to flash to them
When trying AP mode (slow) you are selecting the Arlecxxxxx or Smartxxxx wifi when it asks you to?
I'm sure you are just checking.
And you are on 2 4ghz bandwidth wifi only as well to pair them?
Those steps are usually the ones that are moselt important.
Cheers Carl
Hi @kh17,
I've spoken with the technical team at Arlec (Deta's parent company) who have told me that music mode will only work with music that has been downloaded to your phone, not streamed music through apps like Spotify or Apple Music.
You can download music through these apps so they can be accessed without an internet connection. Try doing this and see what results you get.
If this is not successful, it is likely worth giving their technical team a call on 1300 267 168 in Australia and 0800 003 329 in New Zealand so they can talk you through the troubleshooting process as you do it.
Let me know if you have any further questions or require further assistance.
Re: Grid Connect tips, tricks and help
For anyone that is unaware there is another app called Smart Life that is built on Tuya devices which is the same technology of Grid Connect.
This week they rolled out a fairly big update on the phone app for both Android and IOS
Here is the main new features
1. DIY Homepage Customization
The new dashboard allows for full customization of your app's homepage, ensuring it matches your preferences and smart home setup.
Drag and drop widgets to create your ideal layout.
Highlight your most-used devices for instant control.
Personalize your dashboard to suit your lifestyle.
Your smart home is unique, and the app can now reflect that individuality!
2. Effortless Control for Homes with Multiple Devices
Managing numerous devices is now simplified with The Smart Life App Dashboard, featuring:
Rich control widgets for easy device management.
Streamlined navigation to find and control specific devices more easily.
Enhanced user experience, tailored to large smart home ecosystems.
Whether you have a few devices or a large ecosystem, this update saves time and effort.
3. Android Auto Integration
Enjoy a seamless smart living experience with Android Auto support:
Control your smart devices directly from your car dashboard.
Perfect for managing your home while commuting or on the road.
Provides ultimate convenience with seamless integrations
How to connect Orion gridconnect security cameras to 5G internet?
I recently upgraded my internet to a 5G and discovered that the cameras are only supported by 2..4 and therefore went through the guest network to create a 2.4 connection. I went through the steps of pairing and connecting my cameras and am having no luck. I went through the troubleshooting list and still no luck. Any suggestions would be appreciated.
Re: orion gridconnect security cameras
Hey @annazub,
great question and welcome to the community.
I'm assuming you got a new router as part of the upgrade, and as you point out it has a guest network capability that allows 2.4 Ghz devices to connect.
Specifically Telstra smart modems do this, but I know for a fact that other brand router/modems have similar features:
If you have enabled the 2.4 Ghz network, make sure that you don't have "network band steering" enabled. I had to turn that off.
On my router, this allows devices to try to connect to the fastest of the network SSIDs, and I've found that doesn't work.
Also, on whatever device you are using to pair the grid connect device, after you have done the above, have your device FORGET the network, then connect, and ONLY connect to the 2,4 Ghz SSID, then try to re-pair the security camera.
There's a full troubleshooting guide here: grid connect wifi troubleshooting Option "B`' worked for me, and I've done this for people on Optus modems (slightly different, but ends up in the same place).
Let us know if this helps, or give me the make of your Router and I can see if it's that.
All good thankyou. Family member resolved the issue. Thanks again.
Subject | Author | Posted | |
July 2021 | |||
January 2023 | |||
May 2022 | |||
March 2022 | |||
October 2021 |
