I'm tackling what hopefully will not be too big of an ask for my skillset. I have a 25 M long blueboard rendered front fence that is in dire need of a fix. The blueboard has long gone past it's best & is crumbling off the frame. My initial thoughts were to demo it & have a fencer erect something more aesthetically pleasing. Like everyone, finding a tradie is one thing, getting them to turn up is quite something else again. I removed the sheeting on the house side of the fence to inspect the frame. To my surprise, the frame was generally in good health so I decided to just strengthen the frame everywhere possible & it is now very sturdy. My intention is to just replace all of the sheeting, cover the joints with paper jointing tape & joint compound & then painting. What is the best way to fix the sheeting to the fence frame? Each fence "panel" is 2 x 2400/900 sheets, so 2400 wide & 1800 high. The pics might explain better than myself!
Onto my next & probably most challenging project, the pool deck. As per the pics, it's very obvious that the joists etc are far from serviceable. My thoughts are to just replace each piece of timber with a similarly sized piece of structural H3 pine & then merbau over the top. Any input greatly appreciated.
Kind Regards,
Steve
Steve
Great to see you make you first post on the community after being a member for many years @Sunnycoast5. Welcome to the discussion!
Looks like you have a very challenging project on your hands with the deck, but that blueboard fence repair should be relatively simple. As our resident Bunnings D.I.Y. experts are taking a short break at the moment, let me tag some other helpful members for their thoughts on your questions: @DIY4Knuckleheds, @Nailbag and @Jewelleryrescue.
Hi @Sunnycoast5
I would agree on the plan to reinstate the wall with new boards, tape, compound and paint. You will just need to remove or rebate those strengthen brackets that are surface mounted so the new boards can sit flush.
As a suggestion for a different more modern look to a single plain wall is something like this one I made around a pool. I simply put more timbers to fix cement sheets to and painted them black. Then left a 10mm shadow gap between the sheets before applying a sealing clear coat.
The deck unfortunately doesn't look salvageable at Allas the joist have lost to much of their structural integrity through rot and deterioration. It has been built correctly either as there are long spans where joists haven't been supported with stumps that would have cause the deck to bounce when walked upon. But the sub-floor frame does give you a great head start for a template of lengths and placement for a new one. And there are plenty of resources in the community that @Jason could share links to on how to rebuild it correctly. And with the new build, laying a product like Protectadeck along the top of the joist will maximise the life of the joists.
