How to hang 10kg mirror on plasterboard with metal studs?
yadu
I have a 10 kg mirror with 2 hanging hooks. My wall is gyprock with metal studs as the frame. The hooks of the mirror are 64 cm apart and I am not able to find the studs in the wall (with stud finder) with same distance. Do I need to hang both the hooks in studs ? How can I hang the mirror ?
Re: hang 10 kg mirror
Hi @yadu,
As studs are usually spaced at either 450mm or 600mm intervals, it is very unlikely you're going to find two that line up perfectly with your hooks. Ideally, you would attach both hooks to a stud, but it is not necessarily essential.
I'd suggest lining up one of the hooks with a stud and then using a Ramset WallMate Plasterboard Anchor for the other. These anchors are capable of supporting 10kg per anchor, so using the stud alongside one of these will be fine.
If you'd be more comfortable if the mirror was attached to two studs, you can attach a timber cleat to the two available studs and then hang your mirror from this cleat. This 42 x 19mm DAR Pine Standard can be cut down to around 700mm wide to act as your cleat.
