Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Update 14/08/2024: The Bunnings team have provided the following information on our cutting service.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
Hi @Daiana333,
I'm sorry but I'm not 100% sure what you are after.
Were you looking for advice on cutting a laminate benchtop to go on your kitchen island?
If so you might like to look at How To Cut Laminate Benchtop.
If you were looking for a cover for your kitchen island, there are rolls of cut-to-measure plastic in most stores that can be cut to use as a cover for your kitchen island. If you head to the Special Orders desk and ask for the cut to measure plastic, they should be able to help you out.
If you were looking for someone to do it for you, you might like to use a service such as HiPages or Airtasker to find a handyman in your area who can assist.
Hello,
I'm planning on making a desk tabletop - could you advise if Bunnings would be able to cut these?
This one to be cut to 1600mm;
https://www.bunnings.com.au/specrite-2200-x-600-x-26mm-brown-acacia-multi-use-panel_p0445845
and this one to cut to 1300mm:
https://www.bunnings.com.au/specrite-1800-x-600-x-18mm-brown-acacia-multi-use-panel_p0446743
Thank you!
Hi @Cianyue,
The cuts you've mentioned are fine as they are at 100mm increments.
I know that Bunnings can cut timber to the required length. However, I would like to know if Bunnings can cut timber to the required width.
Can I purchase a 90 mm wide board and ask Bunnings staff to trim it down to 72 mm? Unfortunately, I can not find 72mm boards at Bunnings.
Hi @alex27 , unfortunately no, Bunnings cut shop only has a pop up saw, it is unable to rip lengths down to a certain width just to length. The panel saw is able to cut horizontally and vertically but only on panel timber, not lengths.
Cheers
Shelley
Hello @alex27
Thanks for sharing your question about cutting timber to width. It's great that you've received excellent advice from @twocutekelpies. They are absolutely right the shop saws can't cut to the size you need. However, there is always the option of cutting the panel yourself using either a hand saw or a circular saw. I suggest having a look at this guide - How to choose the right power saw for the job by @Adam_W.
I need to buy a new desk top that is 1400mm x 60mm. I found a white laminate worktop from Practa that is 2400mm x 60mm on the Bunnings website. Is it possible for the bench top to be cut in store down to 1400mm.
Hi @kdufficey1,
Unfortunately, we can't cut benchtops like this in-store.
You can use How To Cut Laminate Benchtop for some guidance on the tools and techniques you can use to cut it yourself.
If you don't have the tools or aren't confident doing this yourself, you might consider advertising the job on a platform like Airtasker or Fiver. You could also look for a local wood shop or men's shed that might be able to help.
Hi, I was wanting to enquirer if any stores in Sydney can cut plywood sheets to size if purchased from that store?
Welcome to the Bunnings Workshop community @Scjcb. It's wonderful to have you join us, and many thanks for your question about our cutting service.
The vast majority of stores offer the ability to cut plywood sheets to size if purchased from the store. Cuts can typically be made in 100mm increments, but please note that precision cuts to the millimetre may not be possible. You can check with your local store for specific details on their cutting services and any associated fees.
