We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Hi @Daiana333,
I'm sorry but I'm not 100% sure what you are after.
Were you looking for advice on cutting a laminate benchtop to go on your kitchen island?
If so you might like to look at How To Cut Laminate Benchtop.
If you were looking for a cover for your kitchen island, there are rolls of cut-to-measure plastic in most stores that can be cut to use as a cover for your kitchen island. If you head to the Special Orders desk and ask for the cut to measure plastic, they should be able to help you out.
If you were looking for someone to do it for you, you might like to use a service such as HiPages or Airtasker to find a handyman in your area who can assist.
Hello,
I'm planning on making a desk tabletop - could you advise if Bunnings would be able to cut these?
This one to be cut to 1600mm;
https://www.bunnings.com.au/specrite-2200-x-600-x-26mm-brown-acacia-multi-use-panel_p0445845
and this one to cut to 1300mm:
https://www.bunnings.com.au/specrite-1800-x-600-x-18mm-brown-acacia-multi-use-panel_p0446743
Thank you!
Hi @Cianyue,
The cuts you've mentioned are fine as they are at 100mm increments.
I know that Bunnings can cut timber to the required length. However, I would like to know if Bunnings can cut timber to the required width.
Can I purchase a 90 mm wide board and ask Bunnings staff to trim it down to 72 mm? Unfortunately, I can not find 72mm boards at Bunnings.
Hi @alex27 , unfortunately no, Bunnings cut shop only has a pop up saw, it is unable to rip lengths down to a certain width just to length. The panel saw is able to cut horizontally and vertically but only on panel timber, not lengths.
Shelley
Hello @alex27
Thanks for sharing your question about cutting timber to width. It's great that you've received excellent advice from @twocutekelpies. They are absolutely right the shop saws can't cut to the size you need. However, there is always the option of cutting the panel yourself using either a hand saw or a circular saw. I suggest having a look at this guide - How to choose the right power saw for the job by @Adam_W.
