what glue and screws are best to put mdf boarding on inside steel shed frame
Hi @Tanya4,
You're going to need a tek screw that is long enough to go through your MDF and penetrate through the steel by about 10-15mm.
You can then use liquid nails as your adhesive.
Thank you for the advise, much appreciated
