Does Bunnings cut wood to size?
Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include MelaminePlywood and MDF.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Update 14/08/2024: The Bunnings team have provided the following information on our cutting service.
  • Cuts to timber and panels boards are rounded up off to 100mm increments. We are unable to do precision cuts.
  • Minimum length of cut timber is 600mm
  • Customer are required to purchase an remaining offcuts measuring less than 1800mm
  • Multiple timber cuts may incur a charge of $1 per cut.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
jec
buy timber cut to size
Hello, I need to buy pieces of treated timber cut to a specific size to make bookshelf shelves (eg 42x36cm). What product should I buy and will Bunnings cut it for me?
thanks
Re: buy timber cut to size
Welcome to the Bunnings Workshop community @jec. It's wonderful to have you join us, and many thanks for your question about our cutting service.
You wouldn't typically find a chemically treated timber suitable to be cut in those sizes. Marine plywood is weather resistant, is suitable to be cut into those sizes and would make some great shelves. Just have a word with a helpful team member in your closest store's timber yard to have it cut.
jitin81
Melamine Board : Cut to size
Hi. I want Melamine Board cut to size to create a shelf in my cabinet. The dimensions will be 72.5 cm in length & 55 cm width. Will Bunings be able to do the cut? I went to my Bunnings store at Tarneit and they say that the minimum cut will be 300cm, is it true? Kindly help.
Re: Melamine Board : Cut to size
Hello @jitin81,
Welcome to the Bunnings Workshop community. It's splendid to have you join us.
I believe there was a bit of miscommunication. The team member probably meant to say 300mm and when you convert your 72.5cm it will be 725mm along with the 55cm which is 550mm. Both measurements are above the minimum allowable cut. It will be possible to have your melamine board cut to size.
Please note that some chipping will occur due to the rough nature of the shop saw. I've placed a sample sketch below so that you can show the saw operator the size that you are after. But just to be safe, please double check the measurements before you commit to having it cut.
cbeadz
longitudinal cut: sleepers
Are treated pine sleepers able to be cut (in half) lengthwise by the Bunnings Cut Shop?
Re: longitudinal cut: sleepers
Hello @cbeadz
Welcome to the Bunnings Workshop community. It's wonderful to have you join us.
I'm sorry but the shop saws are not able to do a lengthwise cut also known as a rip cut. However, it is possible to cut the sleeper using a handsaw or a circular saw.  I suggest having a quick look at this guide - How to choose the right power saw for the job by @Adam_W
If you do decide to cut the sleeper, I recommend using TWA Woodcare 300g Ecoseal Tanalised Timber Treatment to reseal the cut ends.
Please remember to wear personal protection such as gloves, goggles and an appropriate mask when using the spray. Please make sure to follow all the safety instructions printed at the back of the can before use.
SteveSaxby
nearest store with cutting service
All I need to know is the nearest store to me that will cut MDF to size. This is impossible to work out from your website. My postcode is 5113. Let me know or i will just go to Mitre 10.
Re: nearest store with cutting service
Hello @SteveSaxby,
The closest stores to that postcode with a cutting service are Bunnings Munno Para West (closest), followed by Bunnings Gawler and Bunnings Parafield.
I hope that information helps. If you need further assistance, please let us know.
JackF232
French Cleats Battons
Can Bunnings Stores be able to cut some French Cleats for me  so I can install them in my shed.  I have asked at two of your stores but they don"t even what French cleats are.
Re: French Cleats Battons
Hello @JackF232
I'm sorry but the shop saws are not able to do an angled cut for French cleats. They are only able to do straight cuts. However, it is possible to cut the timber using a handsaw or a circular saw.  I suggest having a quick look at this guide - How to choose the right power saw for the job by @Adam_W
A circular saw can be adjusted so that it cuts at an angle. This will make it very easy to create your French cleats. If you are building the cleats to hold your tools, this would be the perfect opportunity to create a cradle for your circular saw as well.
I also suggest having a look at this featured discussion - Custom tool holders on French cleat wall by @fhk56
Please remember to wear personal protection such as gloves, goggles and an appropriate mask when working on your project.
