How to change a washer in a double laundry tap?
Tricia2112
We purchased these taps from Bunnings about 6 months ago. Now the outlet over the tub is dripping.  There are no leaks any where, just over the tub. How do I fix this?
DIYGnome
Becoming a Leader
Re: How to change a washer in a double laundry tap?
Hello @Halimah 🖐
I'm afraid I wont be of much use either as I've never dismantled let alone seen one of these taps before, however every leak I have experienced through the body of a tap fixture has been due to a failed o-ring seal on the threaded shaft.
Hi @Halimah,
As @DIYGnome has mentioned, water leakage from a handle is typically due to damaged o-rings on the spindle. I'd recommend you change the ones seen in your image as yours look to have some damage.
Cedes
I am trying to work out how to change one of these too. I have a brand new hot tap like this which I want to use on the leaking cold tap. I'm confused as to why the hot tap is longer than the cold one since they are a set, but I still need to replace it. Where can I buy a washer? Although the tap is new, the washer leaks. I need a better one. Thanks.
Hello @Cedes,
I suggest having a look at the Syneco 3 - 22mm O Rings Assorted Set - 225 Pieces. You're bound to find a compatible size in the mix.
Once you've replaced the O ring make sure to apply a generous amount of Kinetic 15g Tap Lubricant to prevent tearing up the newly installed O rings.
Cedes
I had a look at that link. Incorrect for what I need. I need washers not o rings...
Hi @Cedes,
We will need to see the washer you want to replace alongside some dimensions to recommend a suitable replacement.
Some photos of the taps that need their washers replaced would also help.
When we have these details, I will assist further.
Cedes
Cedes
I don't know where the other pic came from lol
Hi @Cedes,
You will have to grab a FIX-A-TAP Assorted Washer Kit
One of the washers in this kit will match and replace your existing washer.
Cedes
Ummm no they won't. Inthe original post, the lady was having the correct ones left at the counter I believe, and they were a soft one not hard like these. I have terrible times with hard washers. I always need dome washers to stop the dripping. So I'm after the upgraded ones made especially for this brand as they changed them to the softer ones in the batch after mine. Please refer to the original thread to see what I mean. I need those ones. Thanks. 😊
