We purchased these taps from Bunnings about 6 months ago. Now the outlet over the tub is dripping. There are no leaks any where, just over the tub. How do I fix this?
Hello @Halimah 🖐
I'm afraid I wont be of much use either as I've never dismantled let alone seen one of these taps before, however every leak I have experienced through the body of a tap fixture has been due to a failed o-ring seal on the threaded shaft.
I am trying to work out how to change one of these too. I have a brand new hot tap like this which I want to use on the leaking cold tap. I'm confused as to why the hot tap is longer than the cold one since they are a set, but I still need to replace it. Where can I buy a washer? Although the tap is new, the washer leaks. I need a better one. Thanks.
Hello @Cedes,
I suggest having a look at the Syneco 3 - 22mm O Rings Assorted Set - 225 Pieces. You're bound to find a compatible size in the mix.
Once you've replaced the O ring make sure to apply a generous amount of Kinetic 15g Tap Lubricant to prevent tearing up the newly installed O rings.
