There are areas in one of my house brick wall, the mortar has been watering off. what product to use to refill the mortar
Welcome to the Bunnings Workshop community @jennymelbourne. It's brilliant to have you join us, and many thanks for your question about mortar.
Is the mortar remaining within the bricks powdery and soft? If you take a flathead screwdriver and scrape it, could you easily remove it? If so, you'd likely need to employ the services of a tradesperson who specialises in brick wall stabilisation. There are methods to stabilise the mortar and prevent further deterioration, but they might not be as simple as adding new mortar on top.
Mortar should not deteriorate significantly from water running down the wall, so it indicates that there could be an underlying issue that needs to be investigated by a professional.
Hi Mitchell
Thank you for the advice, where should I get the inspection? what's the name of the specialist?
Hello @jennymelbourne
You'll need to google perhaps a brickwork restoration specialist or a brickwork repair company around your vicinity. You can then ask them if they are willing to investigate the condition of your mortar and see if they can prevent further deterioration.
