Hi, we have upgraded our kitchen recently and is trying to find a solution for this large gap (around 12-14mm) between the cornice and kitchen bulkhead. Can anyone suggest any gap filler that can be used in this case?
Welcome to the Bunnings Workshop community @sallygraham. It's wonderful to have you join us, and many thanks for your question about filling gaps.
The gap I've circled in green could be filled with a standard gap filler. It would be best to push a filler rod into the gap so it's 5mm below the surface. This provides a solid backing for your filler to be applied on to.
The scalloped section is a little bit more difficult, and filler in this area would look quite unappealing. It might be best to take a piece of timber the same thickness and height as the gap and push it inside. You can then trace the profile onto its side and cut it out with a jigsaw. This profiled timber shim can be glued into the gap, and your filler can be applied over it to seal the seams.
Afternoon @sallygraham
Looking at your photo and going through @MitchellMc 's steps theres not a lot more for me to add
Maybe make up a few of those styled segmants MitchellMc has drawn so they can be sandwitched in to build up the overall width? I would make them longer so you dont need a filler rod but really "wiggles hand" either way would look good.
You might need a couple of differeant sizes of widths of timber such as Boyle 915 x 100 x 1.5mm Hobby Wood Sheet to make up that overall distance of 12-4mm
Thank you so much, will give it a shot
Thank you Dave, the link for the timber option comes in handy
