Hi all,
I thought it may he good to have a feed where we could share any tips and tricks to do with any of the Grid Connect Range being Arlec, Deta, Verve, Orion.
I am learning from trial and error and really just accident so sharing with others and sharing back we may be able to create some good learning information for us all.
Please post below starting with what the trick is as the title then how to do so as the body of information.
Carl
Hi @Tinmann , @MitchellMc
I would dare say your primary router is set to 5GHz or 5 + 2.4GHz where by your extenders are probably 2.4GHz.
If your primary is 5+2.4 disable the 5, try to connect your device/s and if successful then re-enable the 5ghz again. If not successful with 5 still disabled try to connect with AP mode (slow flash) mode rather than EZ (fast flash) mode and see if that works.
Don't forget to re enable 5GHz again
That is the 2 main reasons
Let me know how U go
Thanks so much. Great to be part of community that helps each other
Cheers. I’ll try that and let you know how it goes
Hi Tinmann,
I am afraid it is a little more complicated than has been suggested. For a start. the IP address of the range extenders will have to be in the same subnet as your main network ie main router. For arguments sake, say the IP address of your router is 192.168.0.1 Then you need to assign fixed IP addresses to the range extenders that are in the same range ie 192.168.0.XXX Devices that are NOT on the same subnet cannot communicate.
Unfortunately, range extenders use non conventional networking methods. For example, the MAC address of the range extenders is often altered by their software. Normally MAC addresses are fixed on a piece of hardware. That is not the case with range extenders. This means that you may see a range extender listed twice in the routers list of connected devices. All very confusing. Just ignore any device which does not have the IP address that you gave it.
There is a lot of info about range extenders and their weirdness on the net.
However if you make sure all your devices are on the same subnet (ie the IP addresses of all devices start with the same three numbers but have a unique number in the fourth position they should be able to talk to each other.
There is a lot of confusion around the 2.4 GHz and 5 GHz networks on modern routers. Just because the devices are connected to a different radio in the router does NOT mean they cannot communicate. The two radios are linked inside the router and they will have the same IP address structure.
Some people claim to have issues when pairing new Grid Connect devices (which ONLY connect to a 2.4GHz radio) when the 5GHz radio is running.
I have never found that to be the case and I have paired literally dozens of Grid Connect devices.
People also confuse 2.4 GHz and 5GHz in routers with the 4G and 5 G mobile phone networks. They are completely unrelated.
I hope this helps. Computer networking is a complex subject but if you bother to learn the basics you should be able to make any home network perform properly.
Good luck!
I will try to help more if necessary but you really need to have a basic networking knowledge to confidently set up a network.
Ian
Does anyone know if these 2 products are compatible? Thank you.
SG022HA Arlec Bluetooth Smart Button
https://grid-connect.com.au/download/sg121ha/
https://www.bunnings.com.au/arlec-grid-connect-smart-home-button_p0434998?srsltid=AfmBOoroVbrada1MCh...
SG121HA Orion Bluetooth Hub With Socket
https://grid-connect.com.au/download/sg022ha/
https://www.bunnings.com.au/orion-grid-connect-smart-wireless-hub-with-socket_p0330509?srsltid=AfmBO...
Welcome to the Bunnings Workshop community @HJ. It's sensational to have you join us, and many thanks for your question about Grid Connect devices.
The Orion Bluetooth Hub with Socket primarily functions as a hub for Bluetooth devices, including the Arlec Bluetooth Smart Button. While you might be able to set up an automation to have the button turn off the hub, Arlec has not tested this. If you do, you’ll lose connectivity to the button since it relies on the hub’s Bluetooth connection. This means you wouldn’t be able to turn the hub back on using the button. However, they are compatible as they are both on the Grid Connect system
The button is actually designed to control an Arlec White Grid Connect Smart Plug-in Socket with Energy Meter – Single Pack and for other automation tasks. So, if you’re looking to use the button for switching purposes, it might be a good idea to have two sockets—one for your hub and another that can be controlled via the button.
Let me also tag @CSParnell for his thoughts.
Thanks Mitchell.
This is pretty much what I'm trying to do. To be more specific, I have a bunch of DETA smart light switches installed. I want to add a smart button to control one of the light from a different location of the house, where we're not planning to add smart speaker. So I'm planning to get the SG121HA Orion hub and the SG022HA smart button.
Hi @HJ
Just to be clear on this, you'll be controlling a DETA light switch that is linked to the Orion hub and where the smart button is linked to as well. But you want the smart button to talk to the DETA light switch through the Orion hub without affecting any of the other Bluetooth devices attached to it. If my description is correct, then this is definitely a question we'll need to ask Arlec.
Please allow us to contact Arlec in regards to your query. As soon as we have more information, we'll get back to you.
Thank you for your patience.
Hi @HJ,
Yes, the smart button will operate your smart light. Remember that the smart button must be within Bluetooth and the hub range.
@HJ As Mitch stated as long as the push button is in range of the Bluetooth hub you should be able to control just about anything on the Grid Connect network.
I run different brand ZigBee versions of these for my lights at work and the operate fine it's the same principle of a hub and the puch buttons paired to the hub then you set up the push button to control the light see below.
as you can see each touch controls different lights and in different ways.
