Fixing Ceiling panels to Steel Frame House
Hi all...I need to fix some cement board panels to steel ceiling beams in a steel frame house..
What is the best type of screw fixing to use..and do I need to drill a hole for all the screws or is there a better way of doing it?
Re: Fixing Ceiling panels to Steel Frame House
I can only assume that you will be drilling/fixing onto a tophat or topspan product which is probably about 0.70mm thick metal. You could use a timber countersunk screw so you could flush the sheet or you could use a hexagonal tek screw. Either way you don't need to pre-drill unless the sheet is rather thick (ie more than 5-6mm). I pinched the picture below from Stratco website for reference.
Cheers'n'beers
Daryl
Would a timber countersunk screw pierce the metal tophat section without pre-drilling?
The screw in the drawing appears to be something different than an ordinary woodscrew with the flat section at the point..
Does it say on the Stratco website what that screw is?
Hi @Prof
To answer your question, yes. A timber screw will penetrate through the thin steel top hat without any problem. Another fastener to be on the safer side would be something like this https://www.awoodshed.com.au/vstore/index.php?route=product/product&path=19_217&product_id=12909. There would be no problem using a metal screw. Unfortunately I didn't really look at the Stratco site, just wanted to confirm with a picture that this is what you were trying to achieve.
Cheers'n'beers
Daryl
Thanks for your help..
Subject | Author | Posted | |
a month ago | |||
July 2022 | |||
a month ago | |||
February | |||
a month ago |
