Hello DIY wizards: I am hoping to get some advice on how I should proceed with repairing my garage exterior wall. (Products & methods) Any suggestions would be really appreciated! Details and pictures below:
Few weeks ago I noticed a tree like plant growing out of the corner of the wall. It grew quickly and was splitting the render open. I bought stairs, climbed up and yanked it out. The render that was covering the plant roots easily crumbled. There were also ants crawling into tiny holes in the mortar between bricks. I removed the roots as much as I could. There were also some really thin aerial roots. I used a torch to scorch the visible area to burn off aerial roots. Not sure if any remaining roots in covered areas. I also used AntRid for a week until there were no more ants climbing there.
Now, I’m needing some advice on how to best repair this site. I would really appreciate it if someone could suggest specific products and what to watch out for as I am a novice at home DIY.
Hello @icarus1911
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about how to repair your rendered wall.
I suggest having a quick look at this guide - How to repair a rendered wall by @Nailbag. The general steps would be to clean the area of dirt and debris and then patching it up with a bit of mortar. Because you are patching a larger area, I propose using Dunlop 10kg Rapidset Repair Mortar. In order to prevent water from entering this space again, I suggest putting a bead of Selleys 290ml Clear Storm Waterproof Gutter And Roof Sealant - Clear all around the flashing on the corner of your garage. This will protect it from both the weather and the ants from entering that corner.
Hi @icarus1911
This is quite a very large area which is much larger than the process covered in my article. I would be more inclined to use the larger Dunlop repair kit that @EricL recommends. The next step is to try and match the render colour. Unless you know it, I would take a small break-off piece to get it matched prior to repair.
