What is the grip range of Otter 4.8 x 6.4mm Large Flange Aluminium Rivets?
RandomUsername
The Otter 4.8 x 6.4mm Large Flange Aluminium Rivets state a grip of 6.4mm (instead of a grip range like on the other brands of rivets). Will this work with a thickness of 5.5mm to 6.0 mm?
Re: What is the grip range of Otter 4.8 x 6.4mm Large Flange Aluminium Rivets
Hi @RandomUsername,
Thank you for your question.
The 6.4mm in the case of the Otter 4.8 x 6.4mm Large Flange Aluminium Rivets refers to the upper end of the grip range.
With a material thickness of 5.5 - 6.0mm, this size will be perfect for your material thickness.
