Our living room needed a makeover as it was plain and boring. I had an idea in my head of what I wanted to achieve so I got to work. This required removal of a window and bricking in the external wall which was something I had never attempted before but wanted to give it a go. I then began building the timber components (purchased from Bunnings).
The end result turned out better than expected considering this way my first attempt at a feature wall.
https://www.bunnings.com.au/porta-18x18mm-1-2m-dar-square-clear-pine_p0097570
https://www.bunnings.com.au/2400-x-600-x-33mm-hardwood-laminated-panel_p0618957
https://www.bunnings.com.au/gyprock-csr-55mm-x-3600mm-cove-plaster-cornice_p0734031
https://www.bunnings.com.au/dulux-wash-wear-4l-low-sheen-white-on-white-paint-4l_p1370176
TINTED to BLACK
https://www.bunnings.com.au/cableclear-50mm-wall-cavity-cable-management-duct_p4430714
Cleared wall
Planned out a rough design
Stripped wall and removed window.
Bricked in window space.
Plastered wall and painted black.
Built timber book shelf.
Fixed all timber strips to wall 1 by 1.
Wall mounted tv with hidden wiring.
Purchased new tv unit to match.
I also pulled up vinyl flooring and replaced with tiles to finish off the room.
Job Done.
Good Morning @Dundie21
I could only hope to do such a decent job of bricklaying
That looks like you have been doing it for years!
Thank you for the pics and love the story for the hunt of the extra bricks I have done the same with wiggly pavers
That joy when you find some that match what you want
Oh yeah!
Wow looks awesome!
