Okay, I admit defeat! I wanted to try and do this myself but I’ve had to resort finally to some help from you legends and swallow my pride! Hahah!
I have two large poster frames around 5-10kg and I want to hang them side by side above our bed. It’s plasterboard and I don’t have a stud finder, so it’s extra hard to secure things! I bought the hangman canvas hangers, and tried using wall plugs with them too but the wall plugs just keep falling into the wall when I put screws in!
What is the best way for me to do this?
Hello @SarahK1996
I'm sorry to hear that you're having trouble hanging your poster frames. But I think it's important to remember that you gave it a try. I suggest using the Ramset 8 x 64mm Zinc Alloy Toggle With Screw. These have a drop-down toggle and in combination with the screw will provide a secure hold onto your plasterboard wall. These wall toggles can be purchased in a larger quantity.
Here is handy step-by-step guide: How to hang just about anything by @Adam_W.
Thanks so much Eric! I’ll definitely go and grab those!
What are your thoughts on the
Could those work instead of drilling?
Hi @SarahK1996
I would probably use the super strong one like the 3M Claw Picture Hanger 30kg, just to make sure that it will not fall out. It will save you from drilling multiple holes in your wall.
Okay awesome! I might try those first then before putting more holes in the wall! :')
It worked out great with the zinc alloy screws! Thanks Eric! The 3M claws I got didn’t work out well with the type of frames I have because you could see the claw from the top! But it looks awesome! Thanks again for your help!
I have couple of large canvas pictures which is best way hanging gypsum wall? 145 cm by 60 cm size . Which screws good?
thnak you
Revi
Hello @Revi
If your canvas picture has a timber frame, I suggest using the same picture hanging system that Sarah used which is the Hangman 13cm Canvas Picture Hanger. If you are fixing onto standard plasterboard, I suggest using the Ramset 8 x 64mm Zinc Alloy Toggle With Screw - 2 Pack for a secure hold.
Can confirm, these worked a treat!
