Custom-built office desk using Flexi Storage cubes
chaau
Custom Built Desk using Flexi Storage Clever Cube 1 x 2 storage units and Specrite timber panels
Materials
2 x Specrite 2200 x 600 x 26mm Hevea Multi Use Panel
6 x Flexi Storage Clever Cube 1 x 2 Storage Units
Cabot's 500ml Gloss Water Based Cabothane Clear Polyurethane Timber Varnish
Tools
Screwdriver
Drill
Gap Filler
Circular Saw
Stud finder
Steps
Step 1
Assembled all 6 Flexi Storade units
Cut one of the timber panels to make it 450 x 2200. Used the offcut from this panel (approx 145 x 2200) as a back support for the bottom benchtop.
Used the stud finder to attach the board to the studs:
Step 2
Varnished the top and bottom timber panels with three coats of Cabot's Timber Varnish
Attached two Flexi Stotage units to the bottom timber panel
Attached the panel to the backboard
Step 3
Attached the remaining Flexi Storage units to the board and attached the top panel directly to the wall:
Step 4
Finished the project with a few under bench lights:
Re: Custom Built Office Desk
Hi @chaau,
What an ingenious way to create a desk that is both stylish and functional.
I love the way you've used the Hevea Multi Use Panels as a desktop, a storage shelf and as a way to tie everything together.
Congratulations on a fantastic project that you should be extremely proud of.
Re: Custom-built office desk using Flexi Storage cubes
Great work @chaau. What a terrific home office space you have created. I'm sure your work will inspire many other community members.
Fantastic to have you join the community and share your first project with us. Looking forward to seeing more.
Thanks,
riggs12
This is great I might have a go and get this done for my office
Hi @riggs12,
I completely agree, this is a fantastic desk.
If you do decide to give it a go, don't forget to share some photos, it'd be great to see your example.
chaau
Yes, the good thing about this cube system is that it is compatible with other cube systems. I am not going to advertise other brands here, but you can use inserts from other brands to customise your cubes.
vng
What lighting system did you use for lighting ?
Hi @vng,
Allow me to tag @chaau so they are notified of your questions.
Hopefully, they will get back to you shortly with an answer.
chaau
@vng
It was from Ikea. They are sold separately per piece, but you need to buy the driver with the remote controller for them separately.
https://www.ikea.com/au/en/p/mittled-led-spotlight-dimmable-white-30435398/
