Hi Guys
We are on a limited budget and renovating a small 2-bedroom one bathroom cottage. The kitchen is now stripped out and i need to plan a kitchen layout.
rear wall with window is 2700mm with 450mm wall on left of window and 400mm wall on the right side.
Right wall is 2500mmm long
Left wall will have the doorway filled in and can ne up to 3500mm long (3750 to door opening)
We would like sink under the window, and room for a dishwasher.
stove top with oven underneath and range hood on left side
Right side room for large fridge and pantry
Hello @Flash66
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your question about designing your kitchen layout.
I understand that this is both an exciting and stressful time for you as kitchens don't get renovated that often. I understand that you want the cooktop on the left-hand side, but I'm afraid that it will eat up too much of your cabinetry space making it an ungainly layout.
However, I will make another render with the cooktop on the other side. As soon as I'm finished, I'll post it here as soon as I can.
This is a balanced layout with a midsized pantry that allows you to have a large 900 3-drawer cabinet. It's then followed by a blind corner cabinet then an 800mm base unit which is right next to the dishwasher. This is the ideal spot for it as it is right next to the plumbing utilities.
It's then followed by another blind corner cabinet then the oven and cooktop base and finally a 600mm 3-drawer base for pots and pans. A 200mm base cabinet is placed at the end for large serving trays and miscellaneous kitchen items.
Please have a good look at the sample sketch and tell me what you think. If you wish to see it in another configuration, please let me know.
I also suggest having a look at the Top 10 most popular kitchen projects for ideas and inspiration.
Let me call on our experienced members @prettyliving , @lifestylebymari and @redbournreno for their recommendations.
Hi Eric
Love the design and we are really grateful. I was looking at having the tall ie fridge and pantry on the right so I could look at fitting an island bench project timber timber style leaving a 700mm entry what are your thoughts.
Hi Eric the more i look at your design the more i like it , are the timber dining table and cupboards built out of the project panels? And also, could you give me a rundown of what cabinetry i would need to order please.
Hi @Flash66
Hold that thought because I just finished your revised kitchen layout. Have a look and see which one is to your liking.
Hi Eric both are great designs, I just wondered if the second design could have the dishwasher next to the sink, if so I think the Second design might be the go. As you can see on the floorplan for the house it is a small house so need to maximise space
Would it be possible to get a run down on what cabinets I would require
Hello @Flash66
Below are the cabinets I used for your second kitchen design.
The microwave cabinet and the book case cabinet are custom built using SpecRite 2100 x 600mm 26mm Timber Panel Okoume FJ Laminated. However, you can use other timber panels at the store if the Okoume is not available. It's then just simply a matter of varnishing the cabinet with your preferred sealer.
I suggest bringing the kitchen design to your local store and asking the In-Store Kitchen Expert to quote the cabinet list. They can then include all the accessories such as door type, handles, hinges and benchtop to the quote.
