How do you install Kinetic sink strainers?
Henno_K
I can find tutorials on the basket type ones but not these ones. Thank you!
Re: How do you install Kinetic sink strainers?
Hi @Henno_K,
Unfortunately, the strainer you have is not compatible with your sink waste. A compatible sink waste will look like this.
The strainer you have is a replacement part for wastes like this Kinetic Stainless Steel 55mm Sink Basket Waste. You can see there is a rubber ring on the underside of the strainer. In these wastes, the strainer acts as a plug.
You can either replace your waste with a compatible one or return the strainer you have and purchase a strainer such as this Kinetic 38mm Strainer or this Kinetic 50mm Basket Strainer or simply purchase a sink plug.
Henno_K
Ahh bummer! Thanks for the reply Jacob - guess I'm heading back to Bunnings!
Hi Jacob!
We have a sink waste like the one you mentioned in the picture, however it has a screw in the middle.
Our previous strainer looks almost identical, however it doesn’t have the long metal stick down the base.
I have purchased the same one as the OP, but it won’t go in our sink because of the screw. Can I remove the screw or is it important?
Hi @karlyfraser,
A warm welcome to the Bunnings Workshop community, it's fantastic to have you with us.
I would have to see it to give you an answer with any confidence.
Can I trouble you to upload an image of your sink waste?
Let me know if you need a hand with this, I'm happy to help if required.
