How to add drippers to 13mm poly install?
rees70
Hi there, I’m hoping for some help /advice.. I’ve successfully installed my first garden irrigation system… pretty simple 13mm pipe in a three quarter square garden bed. I have 180 and 360 degree sprays that are all working well.
however, I have raised pot that I wanted to run a 4mm drip line to.. when I install it, it pops out… Is there a way to secure this in place to stop it popping out?
Re: How to add drippers to 13mm poly install?
Welcome to the Bunnings Workshop community @rees70. It's great to have you join us.
We had a very similar question last week so I reckon it will be that your water pressure is too high. With any irrigation system, it's suggested to include a pressure reducer such as the Pope 300kPa Pressure Reducer. There's also a 100kPa version to lower it further. Have you got one currently in your new setup?
Hello @rees70
I totally agree with Jason's recommendation. There is probably too much pressure in your system that is causing the drip line to pop out. I suggest installing the pressure reducer to keep the drip line from popping out.
Great, thank you for the reply..,I’ll give that a try…
follow up question… I have installed a automated wireless system.. Holman’s wx1
should the pressure reducer go before or after this ?
Hi @rees70,
I'd pop it on after the WX1, as having the timer hanging off the pressure reducer might not be the most solid solution.
Thanks Mitchell!
put the pressure reducers on and everything is working a treat, thanks!!!
That's wonderful to hear @rees70!
Many thanks for the update.
