shortening height of shelving unit
st22
Cultivating a Following
https://www.bunnings.com.au/montgomery-1830-x-910-x-410mm-5-tier-shelving-unit_p2760578 can I overlap and bolt together legs of such a shelf if too tall?
The manual says not to overlap, but seems it would be better than chopping part of the legs off to shorten.
I got such a shelf second hand and it is too tall.
I don't plan to load to maximum capacity, maybe 50% of maximum load.
st22
Re: shortening height of shelving unit
for example: 90cm + 90cm is 180cm
but i have only 170cm
so 70cm, then 20cm overlap, then 70cm
for example
means 160cm total height
