I am new to this community and embarking on my first project involving Garage Epoxy. I've chosen the Rust Oleum Epoxy Shield Garage Floor Coating Kit for this endeavour. I've already cleaned the garage and performed etching using the Garage Etching provided in the kit.
Could you kindly assist me in reviewing the before and after pictures to confirm the quality of the cleaning? Additionally, do you recommend that I repeat the garage cleaning and etching steps one more time for optimal results?
My next step involves filling cracks using the Rust Oleum Concrete Patch & Repair Patch, followed by the application of the epoxy.
I also have a question: which top coat do you suggest I pair with this epoxy for the best outcome?
Before cleaning and etching -
After cleaning and etching -
Thank you for your guidance and assistance.
Welcome to the Bunnings Workshop community @RK07. It's brilliant to have you join us, and many thanks for your question about preparing a garage floor for painting.
That looks pretty good to me, and I don't see any reason you'd need to do another clean and etch.
Once you've patched the cracks, remember to sand the filler well so it is not proud of the surrounding surface. Take a metal ruler or straight edge and check the surface to ensure it is level. If you leave the filler proud of the surrounding concrete, the filled areas will be very noticeable after painting.
The Rust-Oleum Clear Gloss EpoxyShield Premium Concrete And Garage Coating is the compatible clear coat for Rust-Oleum Epoxy Shield Garage Floor Coating Kit.
Please let me know if you have further questions. I can't wait to see your results.
Thank you, @MitchellMc, for your response.
I have a few more questions (please forgive me if these seem basic; I haven't done any DIY work before):
Thank you for your assistance.
Hi @RK07
If you are looking for an alternative product, I propose looking at the Dy-Mark Epoxy Coat Garage Floor Kit. It's an epoxy coating that resists hot tyre pick up and provides excellent resistance to heavy foot and vehicle traffic.
Please note that there are garage floor paint systems such as the Berger Jet Dry and White Knight Ultra Pave. These are totally different from epoxy coatings.
In regards to sanding down the excess cement, I suggest having a look at the Trojan Concrete Rubbing Stone. But if you have a grinder, I recommend using the DTA 100mm Dual Row Grinding Disc or the Flexovit 115 x 22.23mm Multi Material Reinforced Grinding Wheel. Please note that excessive use will result in a portion of your garage floor becoming very smooth, so use lightly to avoid polishing the concrete.
It's better to paint over the floor first before you apply any gap filler. By doing it in this sequence the epoxy coating will be anchored onto the concrete floor not on the surface of the filler.
Thanks you @MitchellMc and @EricL for your inputs. I have completed the Epoxy over the weekend. Please see below.
I am looking for a top coat for this epoxy layer. Can you please help me choose the one that is suitable for the epoxy? Also, what is the difference between these three options? Do you suggest any other alternatives?
https://www.bunnings.com.au/rust-oleum-3-78l-clear-topcoat-concrete-and-garage-floor-paint_p0347539
That looks fantastic @RK07! Well done!
The difference between those three clear coats is that the Rust-Oleum Clear Gloss EpoxyShield Premium Concrete And Garage Coating is the recommended coating. The EPOXYSHIELD®Premium Clear Coating is the same thing, but that's the US Rustoleum site, and their packaging differs slightly. Here's our version on the AU site. The Rust-Oleum 3.78L Clear Topcoat Concrete And Garage Floor Paint is only for bare concrete surfaces, not painted surfaces.
Thank you, @MitchellMc, for your reply. Here is the final picture after applying the top coat. I'm very happy with the final results, considering it's my first DIY project. Thank you to the entire Bunnings community for the guidance throughout this project.
Hi @RK07
Thank you for that update, your floor looks fantastic. I'm sure the steps you've shared will come in real handy for our members who are thinking of putting epoxy on their garage floor.
Well done @RK07, what a great result. You certainly should be proud of your efforts.
What project are you going to tackle next now that you have a little more confidence in your skills? We would be happy to provide any help we can.
Hi @Jason, Thank you
The next projects I am planning are alfresco tiling and garage sealing for weather and dust protection. I will initiate the discussion in couple of days.
