Can I get opinions on these oscillating multi tools as to whether they are good or bad, and which brands to lookat or avoid. Thanks.
Seeing I am a real newbie to all these new fandangled high falutin thingamebobs.
Some one bought me - probably not a real mutifunction tool - but a renovator and it was so scary I bought the Ozito, and played around with that, true the blades didnt last long, but for the fiddly bits it gave me confidence to use the bigger with more weird blades. Had loads of fun and was great for fiddly little bits and pieces.
Needless to say they have gone for a walk and dissappeared, so it looks like I will be looking out for a new set or just let the 'builder' do all the major bits and I will do the dirty side kick work
Wishing you well
Janina
Great, thanks for letting us know @geejaybee. Glad to see you got plenty of prompt assistance from community members.
I've moved this post to the Interiors board and changed the label to Tools and Equipment so that other Workshop members in future will be able to more easily find the advice.
I use my Ryobi Multi Tool cordless more than I ever thought possible. Brought it as I had gift vouchers to buy a right angle Ryobi Drill at Christmas and had enough to buy a blower and torch, just made an on the spot decision to buy the Multi Tool. I use it more than my original wish gift of the drill.
I really made a bad mistake and used the cutting blade that came with it on a metal bolt wore the teeth out in seconds. My fault but I think in future I will use someone else's blades. And yes I went into Bunnings never thinking about the different sizes in sanding pads and now have to cut the ones I brought down to size as I had opened the packet and if I got the proper sanding pads I would have ended up with twice as many for the same price.
Nice easy to manage light weight and makes difficult corners a breeze.
quote John1:
"I really made a bad mistake and used the cutting blade that came with it on a metal bolt wore the teeth out in seconds. My fault but I think in future I will use someone else's blades."
No sympathy from me mate, everyone knows that the supplied blades are for display purposes only. Besides, you could've saved money if you'd borrowed someone else's multifunction tool, insisted on it being supplied with a diamond blade, & kept it. ; )
