How to replace Ozito whipper snipper parts?
Carlton
I have the below whipper snipper
https://www.bunnings.com.au/ozito-pxc-36v-2-x-18v-300mm-cordless-line-trimmer-kit-pxcltk-2182e_p0082...
Starting to show ware and tare
broke release tab  as below
Other side tab not broken
have contacted ozito no response Can  plastic head parts be replaced at all or can the below universal part be used on otito trimmer
https://littljuey.com.au/products/littl-juey-curved-shaft-head
Bunnings used to stock below part cant find anymore does anyone know if i can get a replacement for this part if so where
Re: ozito whipper snipper parts
Hi @Carlton
I assume since you state Ozito have not responded that you may have only tried to contact via an Online Enquiry? Typically when I don't get responses within a reasonably time or needed to resolve an issue faster, I would make a call or if available chat support. Here are the contact numbers for Ozito.
Ozito customer service helpline
1800 069 486 (AUS)
0508 069 486 (NZ)
It's common for bump caps to wear like yours due to effectively resting the head of the line trimmer on the ground while in use. Hence why the outer edge of the cap has worn all the way through.
Screenshot 2024-12-09 at 6.36.44 am.pngScreenshot 2024-12-09 at 6.36.49 am.png
As a tip moving forward to eliminate the excessive wear on the bump cap, here are a couple of tips to try:
  • Practice holding the weight of the tool up off the ground and not too deep within the lawn. This may require you to hold the trimmer on a different angle to what you're used to in order for the line to cut the edges.
And to help make the trimming line last longer, start further away from the cutting path and slowly make your way in before continuing along. You will also cut much faster with a neater cut. This is because it's only the last 10-15mm of the trimming line thats actually doing all the cutting. When you move too close in, especially against rocks and brick edging, the line bends and wears/breaks further up the line.
Welcome to the Bunnings Workshop community @Carlton. It's fabulous to have you join us, and many thanks for your question about line trimmer replacement parts.
The cover for the spool is available to order through your local store's Special Order desk with part #341130001980.
Great write-up, @Nailbag, with some really helpful information.
