How to remove garage t lock?
diy_vvv
 I am trying to remove this old t lock and replace it with a new one.
I’ve undone the screws however I’m unable to pull it out because of this brown circle thing that’s holding it in place (red arrow is pointing to it).
whats the trick?
how do I get it out?
thanks!
Re: How to remove garage t lock?
Hi @diy_vvv,
I think you'll find that the answer is a little bit more force and considering you are looking to replace the lock, there's no harm being a bit more aggressive.
Have you tried tapping the spindle out with a hammer? I imagine this should get things moving and will allow you to get the handle off.
If this doesn't prove useful, you could try putting a screwdriver down through the slots in the brown circle piece and bending them up.
Give these options a try and let me know how you go.
diy_vvv
Thanks Jacob, I’ve tried the hammer which didn’t work.
I will try a screw driver.
The other question is, what can I use to secure those pieces around the spindle once I break the brown circle?
thanks!
Hi @diy_vvv,
Could you please provide a little more information on what you'd like to secure around the spindle. I'm not sure if I follow.
Many thanks.
diy_vvv
Sure thing.
my logic is that, without that small brown circle (which Jacob i think is suggesting I break ) the other pieces won’t stay in place,
so once i break it to replace the T lock, what else could I use to hold those pieces in place?
Does your new T-lock not come with fixings for it @diy_vvv?
That small brown circle is called a shaft ring and there might be a suitable replacement in this Pinnacle Black Assorted Shaft Rings - 12 Pack. You can typically get them off without breaking them by levering around the outside at different positions. It will take some time to shimmy it off as its job is to lock onto the shaft and not come off. You can try lubricating the shaft and bending the wings slightly away from it. Once you get it off, you can bend the wings back towards the middle so they grip your new shaft.
diy_vvv
Shaft rings! Thank you for giving them a name!
super helpful, will give it a go, thanks!
