G'day All,
So my treadmill is breaking under the workload that is me. Between the rubber belt on my treadmill is a 15mm wooden (mdf?) deck. This is the part that cracks down the middle under my weight.
Customer support has suggested that I attempt to reinforce the deck. I have made my first attempt by screwing wood across the deck, but two out of three of them have come out (I screwed from the bottom up, rather that top down... my bad).
I was wondering if anyone had a simple idea on how I could secure a metal bar across the bottom of the deck?
Note: Pictures to be attached soon.
Hi @Dave-1
The real way that treadmill deck is working is like a swimming pool diving board it is supported at the rear to the frame but the board is free floating upwards to the front of the tread mill. Timber is meant to flex but fails with mdf only has its support in an outer casing skin surrounding the inner mix of glued timber plup Where as ply is laminated top to bottom much stronger as a diving board,
Loook closer all will be reveiled at the GFX cushions they are supporting underneath the board giving the bounce needed to simulate people biomechanics white running acting as minishock absorbers. So the board must be free floating only really attached to the rear to allow this to happen. @topper also wanted to stop the slapping of timber on steel frame with is proof the board suspendeedon the shock absorbers.
Maybe he needs additional gfx cushions for the better exerpiance.
