I would love to get some wall mounted shelving for my garage wall. It is 3m (H) x 6m (W). Just wondering what I could do?
Welcome to the Bunnings Workshop community @JanaF. It's fabulous to have you join us, and many thanks for your question about installing shelving.
What are you planning on storing? If you can let us know more about what you'll be placing on the shelves, including the approximate weight of the items, that will assist our members in providing informed guidance.
Systems like the Flexi Storage wall strips, brackets and shelves are a convenient and easy-to-install option. Alternatively, you could look at installing stayed brackets and your own choice of shelving for a more heavy-duty approach. Check out our range of garage storage solutions.
Here are some helpful guides: Easy ways to create a multi-use garage, 5 tips to organise your garage and How to organise your garage.
Thank you!
I want 2 rows of shelving that are wall mounted. I want it to have a heavy load bearing. I would like to have a 1600 clearance from the floor and then two rows above that. See diagram below.
Thank you kindly!
Then I'd suggest the easiest and most heavy-duty option would be to install stayed brackets at the required height and fix melamine panels onto them for the shelves. Here's a helpful guide: How to drill into bricks.
Thank you for the tips and advice!
