Hi @Maymay
Thank fully damage not to great yet I would use no liquid nails to glue behind the cornice be very care full to just place the glue on the wall and press the cornice onto glue.
Press the cornice on to the glue it wont stick right awy so let the wall transfer some glue and let it sit 10 minutes then re press cornice to the wall this time it should hold like using contact cement. Just to be sure drill a screw or two under the cornice to hold it weight in place by morning it will be fixed.
Remove screws.
Clean up any loose paint egdes and peeling and use no more gaps into the cornice and wall joins , use caulking gun and push excess in with finger if necessary till smooth
A clean wet WHITE cloth will let you wipe away any excess and you may not have to repaint the wall egdes.
Always use white clothes for white area clean ups so you know they are clean. Dark clothes can mark white areas.
Hope its fixed soon
as that cornice has moved ?? might be wise to check the rest of the room for problems
Hi Jewelleryrescue
Thank you for the prompt reply, but something I still not too understand, could you tell me what material I have to buy such as no liquid nails, what sort of glue, then it is easier for me to buy at Bunnings
best regards
Maymay
Hi @Maymay
Glue is ( liquid nails) Selleys 80g Liquid Nails Clear Construction Adhesive I/N: 1232438 $12.55
https://www.bunnings.com.au/selleys-80g-liquid-nails-clear-construction-adhesive_p1232438
Final finish gaps is (No more gaps) Selleys 150g White No More Gaps Multipurpose Gap Filler Tube
Hi Jewelleryrescue
Thank you very much, it is much better for me, I will update my post when the job is done
Best regards
Maymay 😊
It's great to see that @Jewelleryrescue has provided some great advice @Maymay.
Please let us know if you have further questions or run into difficulties.
Thank you @Jewelleryrescue has provided some great advice for me, already maintained 😊
thanks a lot
Maymay
@Jewelleryrescue thank you for the advice. I found this forum thread using Google. I fixed my cornice and it looks great! I left the screws in for extra grip.
The glue was very hard to get out of the tube but I got it done.
Hi @DickyKnee,
I'm so glad that @Jewelleryrescue's advice proved useful for your own repair. I am sure he will be delighted to hear that he could help.
