How to fix damaged cornice?
Maymay
Building a Reputation
How to fix the ceiling strip corner thank you
Jewelleryrescue
Re: How to fix the ceiling strip corner thank you
Hi @Maymay
Thank fully damage not to great  yet  I would  use no liquid nails to glue  behind the  cornice  be very care full to just place the  glue on the wall and press the cornice onto glue.
Press the cornice on to the glue it wont stick right awy so let the wall transfer some glue and let it sit 10 minutes  then re press cornice to the wall this time it should hold like using contact cement.  Just to be sure drill a screw or two under the cornice to hold it weight in place by morning it will be fixed.
Remove  screws.
Clean up any loose paint egdes and peeling and use  no more  gaps into the cornice and wall joins ,  use caulking gun and push excess in  with finger if necessary till smooth
A clean wet  WHITE cloth will let you wipe away any excess and you may not have to repaint the wall egdes.
Always  use white clothes for white area clean ups so you know they are clean.  Dark  clothes can mark white areas.
Hope its fixed soon
  as that cornice has  moved ??  might be wise to check the rest of the room for problems
Hi Jewelleryrescue
Thank you for the prompt reply, but something I still not too understand, could you tell me what material I have to buy such as no liquid nails, what sort of glue, then it is easier for me to buy at Bunnings
best regards
Maymay
Hi @Maymay
Glue  is  ( liquid nails)  Selleys 80g Liquid Nails Clear Construction Adhesive I/N: 1232438  $12.55
https://www.bunnings.com.au/selleys-80g-liquid-nails-clear-construction-adhesive_p1232438
Final finish gaps   is (No more gaps)  Selleys 150g White No More Gaps Multipurpose Gap Filler Tube
Hi Jewelleryrescue
Thank you very much, it is much better for me, I will update my post when the job is done
Best regards
Maymay 😊
It's great to see that @Jewelleryrescue has provided some great advice @Maymay.
Please let us know if you have further questions or run into difficulties.
Maymay
Thank you @Jewelleryrescue has provided some great advice for me, already maintained 😊
thanks a lot
Maymay
That looks fantastic @Maymay. I'm sure you are very pleased with those results.
Well done!
