How to fill gap between concrete slab and Colorbond shed?
I’ve got a 10mm gap between the concrete slab and my colourbond shed, Allowing rain to fall in. Tried using a silicone but didn’t seem to work. Any suggestions?
- Labels:
Plumbing
Repairing
Tools and Materials
Re: waterproofing shed
Hello @bstanl
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your shed.
Generally speaking, a silicone gap filler is what we usually recommend to cover gaps between a wall and a solid flooring substrate. In order to give our members a better idea of what your situation looks like, would it be possible for you to post a few photos of the gap you are speaking of. We can then make recommendations on what you can possibly do to repair the issue.
If you need a hand posting the photos, please let us know.
Hello! On second inspection it looks like there’s an uneven gap on the shed door. The concrete slab looks to be a few mm slope (less than 10mm). I tried using an adhesive door seal which didn’t work. My thought would be to apply a thin layer of silicone to the gap, allowing to dry before using or having a plate attached to the bottom of the door covering the cap.
Hello @bstanl
Thank you for sharing that photo of your shed. If the rain is coming in at an angle and is entering through the gap, I suggest using Moroday MDS2B Self-Adhesive Black Econo Door-Seal. But to make sure that the seal does not fall off, I recommend using some screws or blind rivets to permanently fix it in place. Please remember to drill pilot holes on the door seal to prevent splitting the plastic frame.
Hi @bstanl,
I trust Eric's reply was helpful.
For the benefit of other readers of this discussion, we have a step-by-step guide How to waterproof a shed floor.
Hello! Yes I went to my local bunnings and purchased the recommended door seal and cut to size. Thankyou for the advice.
