How to choose clamps?
Tyro
Becoming a Leader
There are too many clamps to choose from!  😖  I'm starting off my journey into diy-ing with basic outdoor plant stands and a trellis or two, but I have future plans for furniture (chairs, crafting  worktable).  Unable to see myself using any timber thicker than 20mm.
Can anyone suggest a durable clamp that doesn't rust or break?  And what is the most versatile type?
Thanks!
Re: Clamps
Hi @Tyro,
I've found that 300mm Irwin Quick Grips are able to work well on most of my projects. They are easy and quick to use and provide adequate force. If you need more force, such as when you are trying to pull a joint together when glueing, then you might like to also pick up a couple of F Clamps. I have a variety of other clamps, including G style, but I've found the Quick Grip clamps to be the most versatile overall and easiest to use.
Let me mention a few of our members @Renowayoflife, @prettyliving and @lifestylebymari to see if they have any thoughts.
Tyro
Becoming a Leader
Re: Clamps
Thanks Mitchell!  I've yet to buy the Irwin brand so your positive experience gives me confidence in them!
Cheers!
Re: Clamps
I have bought the more budget-friendly quick grip clamps in the past @Tyro, but I won't be again, as although they are cheaper, they are also far inferior to the Irwin variety.
Re: Clamps
Good to know! Thanks Mitchell!
