How do I repair the brickwork?
MegzC
Hi
Does anyone know how I can fix/repair this, inside garage wall.
The bricks are hollow.
Thank you
Re: How do I fix this problem
Hi @MegzC,
Do you want to patch this area so it is flat, or are you looking to make an unnoticeable repair? You could easily fill the area with Prep 750g Watercrete Multi-Purpose Patching Cement. To help disguise the repair mix in some Avista Oxide 1kg Brick Red Cement Colouring with the cement to replicate the original brick colouring. A pointing trowel will come in handy to push the cement into all the voids and create a smooth finish.
