I have an attached garage that was full of junk and just used for storage so idecided to turn it into a cinema room but need to keep access to the backyard as the shed had roller doors front and rear and was the only way to get through.
Materials used where yellow tongue and roughly 90x30 timber for the flooring can't remember the size, black paint for the roof also led strip lights for the floor riser and ceiling the ceiling strip was also stuck to some PVC angle so you can't see the led lights it self just the glow.
I have probably forgot something this whole build was done on a budget and I think has come up awesome the family loves it
Hi @JoshC83
Thank you very much for sharing your home cinema project. Is that the subwoofer under the snack bar? That's a beautiful setup, what's the temperature like in the evening? Does it get hot in summer? If so will you be planning on installing air conditioning?
Hi @EricL
Thanks for the kind words 🙂
Temps at the moment out there are a bit cold of a night but I have a heater I bring out and it heats it up pretty quick and summer I'll use a good fan I think and see how that goes if not maybe a portable air con in the corner.
Good spotting yep that's sub under the snack bar works really well under there and is out of the way.
