Does Bunnings cut wood to size?
Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include MelaminePlywood and MDF.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Update 14/08/2024: The Bunnings team have provided the following information on our cutting service.
  • Cuts to timber and panels boards are rounded up off to 100mm increments. We are unable to do precision cuts.
  • Minimum length of cut timber is 600mm
  • Customer are required to purchase an remaining offcuts measuring less than 1800mm
  • Multiple timber cuts may incur a charge of $1 per cut.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
Re: cutting easycraft panels
Hi @EricL,
Thanks so much for your reply, I really appreciate it! I will get the 2400 panels and go from there. I am delighted that I can get them cut in store as that would be so helpful.
Hopefully the project will end up looking how I hope :smile:
Kathy
RichMD
Re: wood panel cut to size
Hi there, I'd like to order the 2400 x 1200 x 18mm Standard Panel Particle Board online for delivery and have it cut to 1400 x 1200 but can't see anywhere to request this on the website. Can you please let me know if this is possible and advise if the price would be discounted? This would be for the Alexandria, NSW store. Thanks
Hi @RichMD,
I've sent you a PM to offer assistance with your order. By contacting the store directly we'll be able to organise the timber cutting prior to your delivery.
Please let me know if you need assistance contacting the store.
Do Bunnings cut laminated timber panels such as the following along both lengths?
https://www.bunnings.com.au/2200-x-600-x-26mm-beech-laminated-panel_p8330041
Welcome to the Bunnings Workshop community @johnelbadawi. It's fabulous that you've joined us, and many thanks for your question about our panel cutting service.
You might like to discuss your cutting needs with a team member in-store. Generally, these panel type products are not suitable to be cut on our saws. It's a relatively easy task to cut down a board with a circular saw, and I'd be happy to assist as you do so yourself.
You should find these guides useful:
Please let me know if you need any assistance.
tarelder
particle board cut to measure
Hi there. Does Bunnings cut particle board for floors to measure? And deliver? I’m located in KuRingGai.
Re: particle board cut to measure
Welcome to the Bunnings Workshop community @tarelder. It's sensational that you've joined us and many thanks for your question about our cutting service.
Were you looking at something similar to STRUCTAflor 19 x 3600 x 800mm GP YELLOWtongue Structural Flooring
For any timber that needs to be cut before delivery, it's best to phone the store directly before placing your online order. If you speak to a helpful team member at your local store's Trade desk, they'll be able to organise the timber being cut.
williamnuttall
Re: Does Bunnings cut wood to size?
Can Seven Hills cut  1500x600x20mm? For a table top. And can this be dressed?
Hello @williamnuttall
Welcome to the Bunnings Workshop community, Thank you so much for joining us and sharing your question about can Bunnings cut timber for a tabletop and can the top be dressed.
The saws at the store are set up to cut straight cuts. Because the blades used are very large, they produce very rough cuts. There is no dressing or finishing service currently provided at the store. But you can use the Ozito 200W Detail Sander to finish the tabletop. I've spoken to the store and they are currently only open to trade customers. Would you be able to tell me which timber you want to be cut? I can make some enquiries for you at Seven HIlls and make sure that they can cut your chosen timber.
RTDavis
Cutting timber to size at Bunnings.
Do Bunnings cut to size timber purchased from Bunnings?
