Does Bunnings cut wood to size?
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include MelaminePlywood and MDF.
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
  • Cuts to timber and panels boards are rounded up off to 100mm increments. We are unable to do precision cuts.
  • Minimum length of cut timber is 600mm
  • Customer are required to purchase an remaining offcuts measuring less than 1800mm
  • Multiple timber cuts may incur a charge of $1 per cut.
Re: How can I get a sheet of Melamine wood 2 metres long x 45cm wide, cut into 15cm wide length
Hello @JCRiffel
Welcome to the Bunnings Workshop community. It's wonderful to have you join us.
I'm sorry, but the shop saws are not built to make precision cuts. The blades teeth are too big that they often leave a very rough cut. However, it is possible to cut these timber pieces yourself, I suggest having a look at these helpful guides: The D.I.Y. guide to the circular saw and Get to know your circular saw. One of our experienced members @Nailbag posted an excellent example of how to cut with a circular saw in an earlier post. I recommend having a quick look to give you an idea of how it's done.
Hi Eric,
Thanks for taking the time to reply and offering a few suggestions.
I live in an apartment, and prior to moving reduced most of my power tools because of limited space and noise restrictions limit me to what I can use.
The result is that I have reverted to deploying a method I used 40 years ago, using a hand saw and a jig, the width of the hand saw to ensure a straight and accurate cut. I carefully placed "Frog Tape" along the straight pencil line, back and front of the melamine timber to reduce chipping. The method involved patience, however, I achieved the desired result. Thanks.
Re: Does Bunnings cut wood to size?
Hi @JCRiffel
That is good to hear that you've managed to cut the panels down. Please make sure to post a photo update of your project once it is assembled. I'm sure our members will be keen to see what it looks like.
Amirjonak
Cutting Laminate Benchtop
Can I bring my kitchen benchtop to Bunnings for cutting to fit the sink and hot plates?
I appreciate your advice.
Re: Cutting Laminate Benchtop
Good evening @Amirjonak
I am afraid that would be a no. For a couple of reasons. 😕
If you bought a benchtop from within the Bunnings store they may cut it to length (laminate stuff I am not so sure)
They dont do specilised cutting in store, the cuts you are after are a little more complicated then a straight end cut.
There may be a solution tho.
If you havnt ordered your bench you could talk to the kitchen people in store. They can put a special order in and they may cut it all out for you. I have not tried this as yet but think they may.
If you have bought the bench or reusing the bench from another job then Bunnings do have recomended tradies/kitchen installers. You could talk to your local Bunnings kitchen section and they can point you towards the right people. Note the recomended tradies dont work for Bunnings, they just install Bunnings kitchens.
Third option, the Bunnings community can help you step through cutting out segmants of your bench :smile: Just hit us up and I am sure several of us will offer some ways to do it.
Welcome to the Bunnings Workshop community @Amirjonak. It's sensational to have you join us, and many thanks for your question about cutting benchtops.
@Dave-1 has covered it there. Unfortunately, our saws are not capable of doing those cutouts. You'd need to do them by hand with a jigsaw or circular saw. He also makes a great point that if you have not ordered the benchtop yet, we can look at creating a custom order.
If you did want to attempt this yourself, here's a helpful step-by-step guide: How to create a cutout for sinks and cooktops. Alternatively, you might like to enlist the services of a tradesperson through sites like Hipages and Airtasker.
KevInSydney
If I bought 2 plywood sheets (say https://www.bunnings.com.au/2440-x-1200mm-7mm-braceboard-plywood-pine-2440-x-1200mm_p0391229)
could bunnings cut them each into half circles?
(or are circles too difficult on the equipment in-store).
I'm trying to make an 8 foot round table top, and intend to join the two halves.
Happy to drive to any bunnings in greater Sydney if they have the capability.  I also totally understand if you can't cut curves.
I may just settle for an octagon (which is just 2 straight corner cuts on each seat)
Welcome to the Bunnings Workshop community @KevInSydney. We're pleased to have you join us.
As per Mitch's post, the Bunnings timber cutting service is for assisting customers to get their materials home. Unfortunately the team in-store are not able to make precision cuts with their equipment.
Our resident Bunnings D.I.Y. experts are taking a short break at the moment, but they might be able to offer alternative suggestions for building your table. Let met also tag some clever community members such as @Dave-1@JoeAzza and @DIYGnome for their thoughts.
Hello @KevInSydney
Technically speaking the panel you've chosen can totally be cut into a half circle with the tops of the circle being the only offcuts. Using a string and a pencil, I propose tracing a guide for you to cut with a jig saw. However, if you feel that you want a professional finish, I recommend having the materials brought over to your place and engaging the services of handy person to cut the panels for you. But if you wish to take on this challenge, I suggest practicing doing curve cuts on timber offcuts.
Daiana333
Cutting laminate cover panel
I need to cover a cover panel from my kitchen Island is it possible to do for me?
