Hi all - anyone bought a portable aircon for the garage before? I see Bunnings has them, but with an exhaust hose for sliding windows. No windows in the garage, just a roller door. I have plenty of wood work projects but the heat in there kills me (Darwin). A wall unit would do it but would likely cost 2k.
A friend has one in his brick garage, no outside vent. I can confirm it gets hot in there, I haven't yet turned his aircon on but I have the feeling it won't do much as it is a double garage. There was a pop up portable air conditioners shop at my local shopping centre, in what was a fairly cool building to start with they did a good job of pumping out colder air, I don't think if the ambient temperature was in the 40's the end results would match.
I suggest some whirly birds on the roof to get the air circulation going. Next is insulating the underside of the roof. Buy a floor mounted industrial fan and let it circulate the air. It should lower the temperature in the workshop. Perhaps time to consider putting in a large window? Whats the floor area of the garage?
Hi @Totoro,
Great to see you make your first Workshop post and get some prompt and helpful replies. We are looking forward to reading more of your posts soon and seeing your woodworking projects.
Feel free to post anytime you need a hand or have something to share.
Welcome,
Hi redracer - it’s a double car garage, I have a huge pedestal fan but in the buildup season in Darwin it’s a losing game. The roof is insulated I believe (I will double check that). Given the area to cool it sounds like a large wall unit might be needed.
Totoro
Have tried the aircons with vent tube. In Tamworth summer 40 degrees, they struggled to cool a large beedroom. While they took the edge off they didnt cope. In the end we resorted to a box window type. You could just cut a hole in the wall but typically will need a 15amp plug. If you are handy that saves you the $800 to get an aircon fitted on top of the unit price.
James
