Hey
I am going to build a deck that will be about 200mm off ground level and will be 2.5m x 2.5m
I have a few questions
I want to concrete some hardwood fence posts as the stumps
How deep in the ground should they go in?
I will put in 9 stumps. I will buy minimum quantity of sand and rock mix for concrete from the local nursery
How many bags of cement would be needed for 9 holes?
Then I will fix 3 long treated pine joists to the stumps. What size would be suitable?
I will do something similar to this video https://youtu.be/QTQeIZT4U-I
Hi @PatDIY_Dad
That video showed them digging holes approximatly 500mm below ground height asa guide if you look at there auger is has tape lines as depth guages so they go to the same level every time each hole. A suitable depth for purpose.
The trick here is to dig small diameter holes so the timbers go in and less concrete is needed. Larger (deeeper or wider) the holes the more concrete needed.
Look at in vesting/borrowing in a small auger, or a post hole shovel for this task it will help keep hole size smaller.
ps As a must do use H4 treated pine for this type of footing.
I dont recommend buying sand and gravel from the nursery for smaller jobs unless you are also doing more concretng later on. A nursery will charge $70 to 80 delivery fee but will deliver sandand gravel in the same load.
As for concreting the best easiest option is to buy premixed sand and cement bags at bunnings All you have to do is use a wheel barrow is easiest and mix in water and it is ready to go,
Some people use a fast set cement for this that sets fast in near 15mins I highly recommend you dont buy this for your first rodeo as regular sand cement slower setting allows you more time to position things correctly if some thing needs fixing.
For a 500mm hole you will need 2 to 3 bags of sand and cement 20 KG per hole If you have bags left over get a refund on the unopened ones
You want 9 Stumps so thats 27 bags. Probably buy 20 bags initailly and see how you go if bunning quite close to you.
https://www.bunnings.com.au/australian-builders-20kg-sand-and-cement-mix-bag_p0760612
