Moving plumbing pipes in a concrete slab
mlewin
Hi, I had plumbing pipes put in as a provision under the floor in my studio. I now want to change the layout. Do I need to cut the concrete and dig up all the existing pipes and create a new channel in the slab for the new layout?
IMG_4695.jpegthe pipes are all along this wall.
Below is an image of the sewer pipe coming into the building, with the stormwater to the left.
Re: Moving plumbing pipes in a concrete slab
Hi @mlewin,
Thank you for your question and welcome to the Bunnings Workshop community, it is fantastic to have you join us.
I'm sorry to say that you're unfortunately going to have to contact a plumber for assistance with this one.
They'll be able to give you the advice and assistance you'll require to reroute your plumbing in line with the relevant Building Codes and Australian Standards.
The process will likely involve cutting the concrete to remove the old pipes using a Demolition Saw and then cutting new channels for the new plumbing lines.
Once the pipes are installed, they will be wrapped in foam such as Abelflex Self Adhesive Backed Expansion Joint Filler Foam to prevent cracking from the concrete that will be poured to fill the channels.
I'd suggest contacting a plumber to quote on the job and speaking about what you can do to assist and reduce your costs. They may be comfortable having your assistance on parts of the job, but it's always best to check.
Let me know if this is helpful and if you require any further assistance.
