How to replace shower drain?
mookah11
Hello. I was hoping I could remove my old shower drain and replace it with a new drain that is black to match my recently replaced tapware (please see photos). I'm usually a pretty handy girl when it comes to DIY but this is a bit beyond me so I am just wondering if anyone can tell me if this can be done easily or not? And how?
I have tried to research online but had no luck finding anything about removing a shower drain similar to mine. The only one I found sort of similar were screwed on from underneath the showerbase however there is no way to get under this shower base because its straight into the slab. There is no under the house access which makes me think that surely it must be removeable from above. Any advice or tips would be greatly appreciated TIA 😊
Re: Shower Drain Remove and Replace
Hello @mookah11
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about removing your shower drain.
Your research is actually correct, the shower waste is screwed on to the base of the shower tray and the shower tray is then placed onto concrete which fills in the cavity under the shower tray making the shower waste impossible to remove except by removing and dismantling the shower tray. There is the option of spray painting the shower waste just like in this discussion - How to paint a shower grate? by @viide. But please note that because it is spray painted it will not last as long as a chrome plated waste. It will be necessary to touch it up once the paint starts to fade.
Thank you so much for the prompt response Eric. You have immediately told me all I needed to know. Even my next query which was about painting it. I am impressed! Cheers.
