how to fix rotten pole
Samnet
Building a Reputation
Hi, we have been into a new house for about 4 months and there is a rotten pole in the main entrance. Looking for any solution to get it fixed.
Sam
Re: how to fix rotten pole
Hi @Samnet,
Is this post supporting a roof structure?
If so, the only safe method of fixing this issue is to replace the post.
Can you upload some photos of where it meets the roof structure and how it is connected?
It is likely possible to prop the roof structure with Acrow Props, cut out the post and replace it like-for-like with a suitable post.
Once you've provided some more details, I'd be happy to assist further.
Samnet
Hi @JacobZ
Thanks for your reply.
Please see this photo
Saman
Hi @Samnet,
As I suspected, the pole is structural, meaning it will need to be replaced as a matter of urgency.
As the repair is of a structural nature and it is not going to be straightforward, I'd suggest contacting a carpenter for assistance on this one. They'll have the knowledge required to prop the roof structure, remove the post and replace it.
Samnet
Thanks @JacobZ
The structure is supported by a wall and just a portion of it is on this pole. What's your thoughts?
Saman
Hi @Samnet,
While the wall supports one end of the beam, the post still supports the other end of the beam which is supporting the roof.
If the post fails or slips from the post anchor, which is entirely possible considering the rot, then there is a potential that this roof will collapse.
My advice hasn't changed, the post will need to be replaced as soon as possible and it is best that you contact a carpenter for assistance.
Samnet
Thanks @JacobZ
What about this part? Same issue under the deck. A horizontal timber under the deck
Saman
Hi @Samnet,
There is significant decay in that beam which is supporting the rest of the structure of the deck. I suggest you have it replaced as soon as possible.
It's hard to tell from the images, but if this is an elevated deck, you should isolate the area and prevent people from walking over it, as there is a real risk of collapse. Given the decay in this beam, the rest of the structure needs to be assessed by a professional as well.
Samnet
Thanks @MitchellMc
What kind of professional do I need to get to have a look? Carpenter?
Saman
Yes, a carpenter would be the best option @Samnet.
