What screws to use for Ramset Plugs?
alex27
Hello everyone,
Please let me know what type of screws I should use for Ramset 8 x 80mm Long Anchor RamPlug - 8 Pack
The product description says "Suitable for use with 10 - 14 gauge screws".
Are there a special type of screws for Ramset Plugs?
Or, can I use just any type of screws such as timber or plasterboard screws, etc. as long as they are 10 - 14 gauge?
Would 14 gauge screw perform better that 10 gauge screw?
Re: What screws to use for Ramset Plugs
Hi @alex27,
Thank you for your question.
These anchors work by expanding, so the larger the screw is, in terms of length and diameter, the more the anchor plug will expand and the more tension will be created. These Titan 14g x 75mm Batten Screws are about the largest screw you could use with these anchors, but they would be overkill in most situations.
Realistically, any screw that is 10-14 gauge and decently long will work, but there are better options when different materials are being screwed in place. The best screw for you really depends on what you are screwing in place.
If you can let me know what you are screwing in place, I'd be happy to make a recommendation.
