I will be installing skirting soon and was planning on purchasing the Ozito 254 Sliding Compound Saw and the Mitre Saw Table. I am aware that this comes with a 40T blade, but for MDF moulding was informed I should use a 60T or preferably a 80T blade.
In the manual it state that you need to make sure that the blade is not too big, has the right bore hole and also is suitable for the speed.
Ozito
Speed: 4,000
Diameter : 254
Bore: 25.4
Kerf: 3.0mm (assuming this is the thickness)
Is it going to be easy or difficult to find extra blades that will fit?
Has anyone found a 60T or 80T blade that fits and works on this machine?
Hi @Matkai,
The Full Boar 254mm 80T Trade Series Mitre Saw Blade suits your needs. It's 254mm, includes a bush for the 25.4 bore, is 80T and has a max speed of well above your saw capacity.
It's an awesome blade that will be perfect for cutting your trim work.
Is there a Diablo Blade that will fit, have heard they are very good blades as well?
Diablo blades are fantastic, too, @Matkai. The Diablo 254mm 60T Mitre Saw Blade and especially the Diablo 254mm 90T Ultimate Flawless Finish Circular Saw Blade are amazing. They will both run on your saw and include the reducing bush to suit your 25.4mm bore size. I've run the 60T in the past on an Ozito and loved it. I'm pretty sure the blade cost me more than the saw, but boy, was it worth it. It's so nice to do a finishing cut and not have to sand the edge afterwards.
Hi Mitchell, on this topic, I have an ozito drop saw, and recently purchased a new blade for it (with included bushing to adapt the bore size), however the way the ozito blade clamp is designed, it allows the bushing to move slightly inside, meaning the blade has a high chance of becoming off centre. Any suggestions here?
Stu
Welcome to the Bunnings Workshop community @StuartP. It's a pleasure to have you join us, and many thanks for your question about fitting a blade.
Is there any chance you might be able to upload some images or provide more information on how the bushing can move? Let me know if you need a hand uploading images.
If the bushing is the correct size bore size for the saw and it's the same thickness as the blade and locks into it, I'm not entirely sure how it would be able to move around.
