Ozito battery temp & item fault battery
Kkconfused
Ozito battery PXBP-300 3Ah battery put on the charge and item fault and temperature fault light flashing.
Any suggestions about what I can do?
Re: Ozito battery temp & item fault battery
Hi @Kkconfused,
Unfortunately, batteries will degrade over time and require replacing. If you had your receipt and your battery was within the 3-year warranty period offered on Ozito PXC batteries, you could return it for a replacement, otherwise it might be time to purchase a replacement battery.
Any of the PXC range of 18v batteries will be compatible.
