Hi folks!
The weekend DIY renovation of our 80s fixer-upper is now three months in and still very much a building site but we’re almost at the point we can start rebuilding and putting our mark on the place!
There’s two walls where I’d like to install VJ Panels, but I’ve had no luck finding videos or guidance on how do this on brick walls that are rendered and finished with white set plaster - the standard walls in Perth but not the rest of Australia. Aussie videos focus seem to focus on timber frame homes and suggest finding studs, using stud glue and mounting directly onto the wall. A few international videos talk about installing panels onto brick by first placing a timber frame behind, but that doesn’t address what to do when there’s plaster and cornice.
My walls are currently stripped back to plaster and getting patched, but still pretty bumpy so I’ll be delicately skim plastering most walls with Gyprock Top Coat, after which I have to wait 4 weeks to dry before painting.
I’m wondering if it’d be more cost and time effective to prime then install the VJ rather than skim-plaster to neaten, then wall prime, paint, then VJ then paint again. Has anyone here been faced with this choice? Note too this has one of the most damaged plaster corners in the house and I’m honestly hoping to avoid fixing that! See the photos below of the wall - now with paint removed, and you can see its position as the main view from the kitchen as you look down the hallway to the bedrooms.
I’m then not sure exactly how to install the panels onto the plaster - if I need to install a wood frame to mount it on first, how do I deal with the panels sticking out from the cornice? Ideally, I don’t want to remove then re-install the cornices.
Many thanks!
Welcome to the Bunnings Workshop community @JennyB1. It's sensational to have you join us, and many thanks for your question about finishing VJ panelling on an external corner.
You might like to have a read through of this Best Advice article: How do you install VJ panels around a corner? Basically you can either use a moulding or butt join or mitre the sheets and use filler to blend the corner and create a seamless finish.
Ahhh im facing the same issue. The walls they have in Perth houses are good for sound not travelling in rooms and the entire house and for the need to kick a football inside, but omg they really can be a pain in the butt for doing works after the build is done.
Installing batterns before the panels I have considered, but like yourself, it will stick out too far from the cornices.
The wall Im wanting to install the panels onto is a double brick
external wall with the slight cavity in between the bricks, so im hoping that this cavity will be ok for moisture release.
Awesome tips. The 16G brads that you use, what length do you use? And do you use a nail gun/brad nailer to fix them?
Hi @jordcam1983,
Allow me to tag @ProjectPete so they are notified of your questions.
He has indicated that he uses 15-20mm brad nails to hold the panels in place while the liquid nails, which does the majority of the work, cures. I'd suggest you'll need to use a brad nailer, such as this Trim Master Gas Bradder which can be hired from your local Bunnings store.
It is worth mentioning that while it may work, it is not the advised method of installation, so the manufacturer will not warrant its installation. If you are fine with this, then there's nothing stopping you, but you should be aware.
