How to install Ametalin XR HD SilverSark?
handiher19
Good morning Brains Trust
We are removing our roof to upgrade the tie downs to the rafters and top plate and while we had the metal roof off, we want to Sark it. But i cant find anywhere the install guidelines for the Ametalin SilverSark. Can you point us in the right direction for install. Also we are getting conflicting info - do we go over or under battons
Re: installing Ametalin XR HD SilverSark
Hi @handiher19,
Thank you for your question about the installation of Ametalin XR HD SilverSark.
Similar to you, I've been unable to find an installation guide for this particular product. The specific details around installation are unfortunately hidden behind a paywall in AS 4200.2:2017 Pliable Building Membranes and Underlays, Part 2: Installation.
I can say that sarking is usually attached to the rafters with Ametalin 25mm x 22mm Cap Nails with Ametalin 72mm x 50m Reinforced Insulation / Ducting Tape to seal the seams before battens are run over the top. The sarking should be laid horizontally, starting from the bottom of the rafters, and working up towards the ridge so that each subsequent row overlaps the one below it.
Unfortunately, you may need to contact a licenced roofing contractor to assist with the install and to offer advice on the correct method of installation in line with the Australian Standards.
