Hi
My house is 7 plus years old and their are a lot of hair line cracks devolving in the front facade of my home on different walls.
I have been recommended to use render refresh as the cracks are mostly hairline.
Has someone used this solution before and is it effective or just a waste of money.
Do you have any alternative approach to resolve this issue. Attaches is just one example of a wall which has cracks
regards Pratik
Hello @pratikpatel
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thank you for sharing your question about repairing the cracks in your facade.
I suggest trying this method, use a Josco 3 Piece Hand Wire Brush Kit to clear out the dust and debris in the cracks, then fill them in with Poly 500g Exterior Masonry Poly. Make sure to use a Pro Renovator 38mm Plastic Scraper to prevent damaging the surface. Wait for the filler to cure and then you can sand down any imperfections. It will be necessary to repaint the area as Polyfilla's finish will not be the same colour as your facade.
